This command disables the generation of one or all default routes in the LSPs for the specified router process.
| area_name | Specifies the name of the IS-IS router process that should no longer generate the default route. |
| ipv4 | Specifies that the router process should no longer generate the default IPv4 route. |
| ipv6 | Specifies that the router process should no longer generate the default IPv6 route. |
IPv4: Disabled.
IPv6: Disabled.
This applies to level 2 routing only. By default this command disables IPv4 default route origination. The optional ipv6 keyword disables IPv6 default route origination. This command has no effect on router processes that are already disabled for default route origination on level 1-only router processes.
The following command directs the IS-IS process named areax to stop generating the default IPv4 route in it‘s LSPs:
disable isis area areax originate-default
This command is available on platforms with a Premier license as described in the Switch Engine v33.1.1 Licensing Guide document.
